Aug 23, 2019 6:06 PM UTC
Password Flow - errorCode OAU-123 "Client authentication is required"
I have followed the instructions for the Password Flow. Instead of receiving a token, I am receiving error OAU-123 "Client authentication is required."
I am using VBScript so I cannot use any of the provided libraries or examples.
I created a new application in the ringCentral console with the type of Server-only (No UI) and permissions of Read Accounts, SMS, and Webhook.
I have concatenated the app's client ID+":"+client secret, then encapsulated the entire string to base64.
authString=base64Encode(clientId+":"+clientSecret)
I am testing with the sandbox url "https://platform.devtest.ringcentral.com".
My endpoint is "/restapi/oauth/token".
I open an async POST to the url and endpoint.
objHttp.open |POST|, url+endpoint, async
I then set the following request headers.
objHttp.setRequestHeader "Accept", "application/json"
objHttp.setRequestHeader "Authorization", "Basic "+authString
objHttp.setRequestHeader "Content-Type", "application/x-www-form-urlencoded;charset=UTF-8"
I post the following data:
"grant_type=password&username="+userName+"&extension=101&password="+password
I get the following response:
"error" : "invalid_client",
"errors" : [ {
"errorCode" : "OAU-123",
"message" : "Client authentication is required"
"error_description" : "Client authentication is required"
I have verified that I am using the correct sandbox Client ID and Client Secret. I have tried resetting the user password. I have tried the user email address as the username, and the phone number with and without the leading "+", url encoded and clear. I always receive the same error.
Google searches for this exact wording have returned no results. Nor is this error listed in the RingCentral errors documentation. (https://ringcentral-faq.readthedocs.io/en/latest/errors/).
Any help would be appreciated.
Aug 23, 2019 8:24 PM UTC
I am not sure about vbScript but currently, I don't see any issue in your parameters and url to call OAuth token API, not sure about the code though. Maybe someone else here can help with the code
It may not be an issue from your side. I found something similar here:
https://forums.developers.ringcentral.com/questions/285/error-oau-123-authorization-header-is-not-specifie.html
Please check with the back-end support team once to make sure the issue is not from your side by submitting a help ticket.
Aug 26, 2019 1:08 PM UTC
Thank you for your reply. Using an API debugger (Runscope) I plugged in my code generated parameters and successfully received a token response. At this point I'm convinced that it is the Windows WinHttp object itself causing the issue. I have noticed that if I do not send an Authorization header at all, I get the same response. If I send an invalid Authorization header (just a few characters), then it produces a different error. This leads me to believe that it the Authorization header is not being attached. There may be an issue with the length or content of the authString. I will post any resolution if I find one.
