Feb 5, 2021 3:49 AM UTC
Permission Issue
So I created 2 little applications to 1) read data from the logfiles and 2) to get a list of users.
The first one is working fine using the API
The second one returns
  "errorCode" : "InsufficientPermissions",
  "message" : "In order to call this API endpoint, application needs to have [ReadAccounts] permission",
  "errors" : [ {
    "errorCode" : "CMN-401",
    "permissionName" : "ReadAccounts"
I have tried all the possible permissions, including Read Accounts, with no luck. I even gave the app every permission available. Still the same.
Any ideas?
    Feb 5, 2021 4:13 AM UTC
    What API call returned that error?
    Feb 5, 2021 4:37 PM UTC
    https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/directory/entries
    and even if I gave the app every permission, I was getting the same response.
    Feb 5, 2021 7:14 PM UTC
    Ok there is clearly something up. Created app #3 with the same authorization and that works.
    I think if you update the authorization after you create the app, that is not working at RingCentral
