Mar 6, 2024 2:36 PM UTC
Problem Authenticating with Ring Central Legacy Phone App
We are trying to test in our sandbox using the legacy phone app located here:
https://support.ringcentral.com/download.html
install file: RingCentral-Phone-24.1.3.msi
We must use the legacy phone to allow calling out with the API. When we try to login to the phone we get "Login Failed", but we are using the same credentials that work for the current phone and web-based client.
The user we are logging in with: cdctestitesa@gmail.com
Phone number: +16282312316
Main number: +16268994541
Account ID from API endpoint: 422160004
Thanks,
George
    Mar 6, 2024 3:17 PM UTC
    Did you switch the soft-phone app to sandbox mode?
    gschallyThe First StepAuthor
    Mar 6, 2024 5:16 PM UTC
    Thank you! We were unaware of that method.
    We have the phone installed now, but when we look for devices for the extension with the API, it shows as "Offline", even though we are running the phone. Is this the correct app to run that returns a valid device ID for calling out?
    Mar 6, 2024 8:49 PM UTC
    The instruction to switch between sandbox and production is available in this page on the right-hand side.
    Yes, it's the right app. However, we don't support device/phone setup for this softphone anymore. So you must login the admin portal and set a valid emergency address for the user. Then login the softphone app and try to make a phone call. If you can call a number from the softphone, the system will register the softphone device and you can read and see the device status as "online".
    Mar 8, 2024 2:50 PM UTC
    For the suggested work-around, we are unable to dial out with this phone. Calls appear to dial then end with "Call Status: Cannot Reach". We have tested successfully previously with the Avaya Cloud Phone located here:
    The customer has shown me in this Avaya phone there is an option for Direct Dial instead of Ring Out, and he thinks this is preventing outbound calls from working.
    We can't use this phone in the Sandbox, however, and we can't graduate our app credentials in Production until we properly test in the sandbox.
    Do you have any advice?
    Mar 8, 2024 2:53 PM UTC
    Give me the app client id. I will graduate the app manually for you.
    Mar 9, 2024 12:07 AM UTC
    I really appreciate your help through this process. Thanks.
    ClientId:
    YMlhFH81xWId7qXgkTOmDU
    Mar 9, 2024 12:21 AM UTC
    Done.
