Jun 27, 2018 10:56 AM UTC
Problem integrating RingCentral Embeddable Voice
I am trying to integrate RingCentral Embeddable Voice in my application and I am receiving this message in my console.
Mixed Content: The page at 'https://ringcentral.github.io/ringcentral-embeddable-voice/#' was loaded over HTTPS, but requested an insecure resource 'rcmobile://call?number='. This content should also be served over HTTPS.
What can I do to solve this?
Jun 27, 2018 12:17 PM UTC
Hi, Felipe Does your application support 'https'? Now RingCentral Embeddable Voice is deployed on https. And browser require application that integrate it to use https
felipeThe First StepAuthor
Jun 27, 2018 1:57 PM UTC
I got it to pass the initial problem but now I get this:
progress...
app.js:1 rejected
app.js:1 Event: Failed
app.js:1 Incompatible SDP
app.js:1 Event: Terminated
What is Incompatible SDP?
Jun 27, 2018 2:00 PM UTC
Also this
app.js:1 Wed Jun 27 2018 16:59:04 GMT+0300 (Eastern European Summer Time) | sip.transport | unable to send message, WebSocket is not open
Jun 28, 2018 6:22 PM UTC
Hi @Felipe, Can you capture the SDP for me by following this steps ?
1. Login to widget
2. Right click on the widget
3. Open Developer Console
4. Select Network tab
5. Select web sockets menu
Jul 2, 2018 12:33 PM UTC
Sorry @VB for the late response. Here it goes.
Jul 3, 2018 3:14 AM UTC
Can you please show me 488 Message on the
Jul 3, 2018 9:18 AM UTC
Jul 6, 2018 7:23 AM UTC
Any news @VB?
Jul 6, 2018 6:03 PM UTC
Hi Felipe ,
Can you reach me out at vyshakh.babji@ringcentral.com  . Lets go over it . I am assuming the app is not setup right. Also, have you tried to install RingCentral Google Chrome Extension app? do you have the same issue ?
Jul 9, 2018 8:24 AM UTC
Hello @VB,
I think we have a different timezone, so I just can see your answer in the next day.
As I mentioned before the extension for chrome works for some reason which I don't know.
