Jan 8, 2025 7:29 PM UTC
Problem to send call api obtain data ringcx
Hi comunity.
I’m working to API for get information about rincx platform, however i recived the next issue to send the call API for obtain the data:
API TO ASK DATA RESPONSE ON RINGCX
Can you helpme to understand whats its the problem, when i send the API call for obtain information about RingEX, the response it’s correctly.
API TO ASK DATA, REPSONSE ON RINGEX
Thanks.
    Jan 9, 2025 12:47 AM UTC
    You wrote RingCX and you also wrote RingEX. What API did you exactly call? What kind of account info do you want to read?
    Jan 9, 2025 1:11 AM UTC
    Hi PhongVu.
    I working about RingEX and RingCX   and yours APIS, the first APIS for RingEx run correctly, but for RingCX the apis call sendme the issue indicate in the picture.I obtein a issue 500 when i send the api call for ringcx.
    Jan 9, 2025 6:10 AM UTC
    Hi PhongVu.
    Again, what is the API you called?
