Jan 16, 2019 11:44 AM UTC
problem with curl in php on ring-out
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL,"https://platform.devtest.ringcentral.com/restapi/v1.0/account/~/extension/~/ring-out");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS,
http_build_query(array('from' => '+12048184079',
'to' => '+17604762222'
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$headers = [
"Content-Type: application/json",
"Accept: application/json",
"Authorization: Bearer U0pDMTFQMDFQQVMwMHxBQUFtdWhQcG5lYk4xbUIwc2pyaXpqTVZJZnlxUWhENlEtc2NRcTNxYmZaRXl5Qk9nSWk2RDFiMjVFTy0zaXhsVGlWNF9QWWRPMEVYNENYQjd4dmJsWHJoVTBsTVl2VlA1XzNIczcycTVONm13eDY5d3o3YWkwN3l5Wkt3clFLVDl0Y3FmajJQZ0tRSUtmRnhjNGJua1lHbmxxSElJTzBnOUxab0dZR19MVlo5bGhDU2pMcE1oYm5jRG9icVRYbUswSm14VzI3VmdrNjR2aVZxUGt6bU9aOUN8amhaMGtnfFZFM1ZGamhpaTdKcjc2dkRzSDEzMGd8QUE"
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$server_output = curl_exec($ch);
echo "<pre>"; print_r($server_output); die;
curl_close ($ch);
output: -
{    "errorCode" : "InvalidJson",    "message" : "Unrecognized token 'from': was expecting 'null', 'true', 'false' or NaN
 at line: 1, column: 6",    "errors" : [ ]
Jan 16, 2019 3:13 PM UTC
Please use
instead of
Jan 16, 2019 3:43 PM UTC
Hi Andrew,
The content type is "application/json". Here is the way to create the body for the API call
$params = array(
        'from' => array('phoneNumber' => '+12048184079'),
        'to' => array('phoneNumber' => '+17604762222')
curl_setopt($ch, CURLOPT_POSTFIELDS, json_encode($params));
+ Phong
