Oct 19, 2023 12:20 PM UTC
Python/Databricks: Resource for parameter [accountID] is not found
I am using Python inside of Databricks to make a call to the Data API for the call log sync. I am using JWT auth. I am following all of the instructions given on the developer website. I am able to successfuly login with JWT, but when I try to hit call-log-sync api with my accountId found in the Sandbox credentials I get the following error: Resource for parameter [accountId] is not found
I have confirmed that my account has access to the app, which has the proper permissions. What else do I need to do to get this working?
    Oct 19, 2023 1:52 PM UTC
    Can you share the code with the path and the params which you used for calling the API?
    Oct 23, 2023 1:21 PM UTC
    Oct 23, 2023 3:34 PM UTC
    To avoid providing a wrong account id, you can use the tilde '~' (as shown in all our sample code) sign instead of an account id. The system will detect the account based on the user access token.
