Feb 9, 2022 5:17 AM UTC
RealTimeUpdates not working for DoNotDisturb of RingCentral adapter when changing state from state Invisible to DoNotDisturb
RealTimeUpdates/Webhook event is not working for DoNotDisturb of RingCentral adapter when changing state from state Invisible to DoNotDisturb.
Steps :
  1. Login with sandbox number in RC Phone app
  2. Change the status to Invisible
  3. Now change the status to DoNotDisturb
Actual Result : We are getting the same webhook event as Offline for both Invisible and DonotDisturb status.
Expected Result : For DoNotDisturb status, we should get DoNotDisturb as presenceStatus.
Application using : RingCentral Phone app.
Hope this issue will get fixed. Will be waiting for the issue to be fixed.
Thanks in advance!
Usha Naidu
Email : usha.naidu2011@gmail.com
Contact : +919890379325
Feb 9, 2022 3:58 PM UTC
What is the presence notification status you showed above? Is that the one you said it does not work?
Feb 9, 2022 6:36 PM UTC
DND status already shows 'TakeAllCalls' / 'DonotAcceptAnyCalls' when you switch DND right?
Presence is Aggregated presence status, calculated from a number of sources which mean that is is the status of the device - Offline, Busy, Available
