Jan 16, 2019 11:49 AM UTC
Receiving "unauthorized_client" error when using php curl for auth/token
  "error" : "unauthorized_client",
  "error_description" : "Unauthorized for this grant type",
  "errors" : [ {
    "errorCode" : "OAU-251",
    "message" : "Unauthorized for this grant type"
Here is my code below:-
$ch = curl_init();
curl_setopt($ch, CURLOPT_URL, "https://platform.devtest.ringcentral.com/restapi/oauth/token");
curl_setopt($ch, CURLOPT_RETURNTRANSFER, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS, "username=+12048184079&password=Reset321$$&extension=101&grant_type=password");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_USERPWD, "1RjNgM-LTxxxxxFuE-ggrHA" . ":" . "524fjcxxxxxxxxxxCPclIZHxxxxxx_FdfegzA");
$headers = array();
$headers[] = "Accept: application/json";
$headers[] = "Content-Type: application/x-www-form-urlencoded";
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$result = curl_exec($ch);
echo '<pre>'; print_r($result); die;
if (curl_errno($ch)) {
echo 'Error:' . curl_error($ch);
curl_close ($ch);
Jan 16, 2019 12:08 PM UTC
Hi Andrew,
The following grant types are available for your application:
* Authorization Code
* Refresh Access Token
Please find instructions on how to use these flows:
https://developers.ringcentral.com/api-reference#OAuth-2-0
https://ringcentral-api-docs.readthedocs.io/en/latest/oauth/#authorization-flows
Thanks,
Igor
Jan 16, 2019 12:25 PM UTC
can you correct my code or give me the exact code according to my php curl for this error
Jun 20, 2019 7:44 AM UTC
The screenshot shared by you seems you have created application of platform type server/ web which supports grant_type=Authorization code while you are trying grant_type=password.
You need to create application that support grant_type,=password or password flow in ring central terms
