Dec 27, 2021 11:00 PM UTC
RingCentral.Net - RingOut doesn't place call when 1st leg is RingCentral number
Our users work off a dashboard of patients, each patient listed with name and phone number. Each of our users has their own RingCentral account and individual phone number. When a user clicks a patients number (from the dashboard), the application (browswer based) utilizes the RingCentral.Net NuGet package and fills out the "MakeRingOutRequest" object with the RingCentral number of the user in the "from" field, the number of the patient in the "to" field, and then the RestClient is called via ...
restClient.Restapi().Account().Extension().RingOut().Post(makeRingOutRequestObject);
This all works fine in the Sandbox account, but not in production. In production, if I use my mobile phone number (rather than my RingCentral account number) to make the call, everything works fine as well. Any ideas on how to resolve this would be great.
Thanks,
Shelby
Dec 28, 2021 3:27 AM UTC
What device are you using for RingCentral number? Do you use soft phone / Webphone or Hardphone ? What does the Ringout status say ?
Can you check the ring-out status using this api and let me know the final response of the call?
https://developers.ringcentral.com/api-reference/RingOut/readRingOutCallStatus
Dec 28, 2021 3:14 PM UTC
In my case (our RingCentral account) I'm using the "RingCentral Phone app" (softphone). Some of our other clients, that are experiencing this issue, may not be, but I haven't gotten that far yet.
Looking at the call logs from a ringOut call that I just tried to make, I'm seeing a "result" of "IP Phone Offline". Looking at our account pages, my device is showing a status of "Offline.
I am logged in to my RingCentral phone desktop app and can make outbound calls from there. If the problem is that my phone is "offline", what can I do to remedy this?
Thanks,
Shelby
Dec 29, 2021 1:00 AM UTC
Do you see the "Deauthorize this Computer" button? If so, click the button and logout from the soft phone, close it (kill the app) and reopen and login.
Also, you wrote when 1st leg is RingCentral number. Does it work if the RingCentral number is the 2nd leg?
Dec 29, 2021 6:54 PM UTC
Account Id: 2943723020
