Jun 4, 2018 5:51 PM UTC
RingCentral Nuget Package and Paging
We have created a program that will download all extensions (about 2000) into a spreadsheet so we can modify and do some other things with them. During development everything went fine, but now that we are in production we cannot get more than ~100 extensions to come down.
We are using the RingCentral Nuget package, and I do not know how to set perPage setting.
Jun 4, 2018 7:00 PM UTC
Hi ,
Assuming you are using /account/~/extension API to fetch extension info ,  here is the response you will get
  "uri" : "https://platform.devtest.ringcentral.com/restapi/v1.0/account/131074004/extension?page=1&perPage...;,
  "records" : [
//ext details
  "paging" : {
    "page" : 1,
    "totalPages" : 1,
    "perPage" : 100,
    "totalElements" : 8,
    "pageStart" : 0,
    "pageEnd" : 7
"navigation" : {
    "nextPage" : {
      "uri" : "https://platform.devtest.ringcentral.com/restapi/v1.0/account/131074004/extension?page=2&perPage...;
    "firstPage" : {
    "lastPage" : {
      "uri" : "https://platform.devtest.ringcentral.com/restapi/v1.0/account/131074004/extension?page=4&perPage...;
You can use "next" navigation page url to seek to next page with the list of extensions  .
Jun 5, 2018 1:51 AM UTC
This is the official NuGet package that we support: https://github.com/ringcentral/ringcentral-csharp-client
It is possible to specify the perPage parameter.
https://github.com/ringcentral/ringcentral-csharp-client/blob/master/RingCentral/Paths/ExtensionPath...
Sample usage:
rc.RestApi().Account().Extension().List(new { perPage = 1000 });
The maximum perPage allowed is 1000. If you have more records, you still need to handle pagination. Please refer to VB's answer for pagination handling.
