Mar 28, 2018 8:12 PM UTC
RingOut problem using extensionId
I can ring out successfully requesting:
https://platform.ringcentral.com/restapi/v1.0/account/~/extension/~/ring-out
But when I want to add the extension id I get a CMN-102 error (Resource for parameter [extensionId] is not found) see request example below:
https://platform.ringcentral.com/restapi/v1.0/account/~/extension/279580017/ring-out
I'm pretty certain I have the correct id as I'm grabbing the extension Id from the request below successfully:
If anyone has run into this or can point out any potential pitfalls I would very much appreciate some pointers.
Mar 28, 2018 9:44 PM UTC
Hi Joseph,
as far as I can see you use the access token issued for System Admin User but specify the ID of another extension in your URI. It is not allowed: user can only make ringout calls on behalf ow his/her own extension. When you specify tilde it will automatically applies current user's extension ID.
Hope I made it clear.
Mar 29, 2018 5:16 AM UTC
Feb 10, 2025 9:32 PM UTC
Hi Joseph,
it’s been 6 years since this post, is that still the case?
