Setting subscriptions aggregated query parameter to true using the c#.net SDK
In the API Docs, it states if you want the subscription to return certain parameters, lets say, dndStatus on a Presence event, the aggregated query parameter on the subscription request need to be set to true. I am unable to see where you can set this parameter to true using the c# .NET SDK. Is this not a option using the SDK?
