Nov 17, 2022 3:37 PM UTC
speaker timeline for calls recorded
Is it possible to get a speaker timeline for calls recorded on Ringcentral using API? Or even get recording for each speaker on separate channels
    Nov 17, 2022 9:43 PM UTC
    Unfortunately, that metadata is not supported.
    If this is critical for your use case, you can download call recordings and use a 3rd party speech-to-text service to transcribe the recording and get other metadata such as speaker ids and timelines etc.
    You can also send a request to access RingCentral AI API and you can use the /speech-to-text or the /analyze-interaction API to transcribe call recordings and grab the metadata.
