Dec 23, 2022 12:40 AM UTC
Subscription not created when using production
I have a simple app that just logs out responses from the telephony subscription. It works great in the Sandbox, but after I graduated it and use it in Production (and changing credentials), it does not create a subscription (I use this to check: https://developers.ringcentral.com/api-reference/Subscriptions/listSubscriptions). But I don't see any errors in the console.
It does print out "Ready to receive Telephony via PubNub." so it seems like it worked, but I don't see a subscription listed. Just wondering how I diagnose this further, or if I am missing something.
const RC   = require('@ringcentral/sdk').SDK
const Subs = require('@ringcentral/subscriptions').Subscriptions
require('dotenv').config();
var rcsdk = new RC({
    'server':       process.env.RC_SERVER_URL,
    'clientId':     process.env.RC_CLIENT_ID,
    'clientSecret': process.env.RC_CLIENT_SECRET
var platform = rcsdk.platform();
platform.login({
    'username':  process.env.RC_USERNAME,
    'password':  process.env.RC_PASSWORD,
    'extension': process.env.RC_EXTENSION
var subscriptions = new Subs({ sdk: rcsdk });
var subscription = subscriptions.createSubscription({
    pollInterval: 10 * 1000, renewHandicapMs: 2 * 60 * 1000
platform.on(platform.events.loginSuccess, () => {
    subscribe_for_telephony_notification()
function subscribe_for_telephony_notification() {
    subscription.setEventFilters(['/restapi/v1.0/account/~/telephony/sessions'])
        .register()
        .then(function(subscriptionResponse) {
            console.log(subscriptionResponse);
            console.log("Ready to receive Telephony via PubNub.")
        .catch(function(e) {
            console.error(e);
            throw e;
    console.log(msg.body);
Dec 23, 2022 4:21 PM UTC
First of all, you don't need to call this line. The SDK does auto refresh and keep the subscription active as long as you keep the subscription instance.
{ pollInterval: 10 * 1000, renewHandicapMs: 2 * 60 * 1000 }
Then add and call this function to list all subscriptions created by your app
async function readAllSubscriptions() {
  try {
    var resp = await platform.get('/restapi/v1.0/subscription')
    if (jsonObj.records.length > 0){
      for (var record of jsonObj.records) {
        if (record.deliveryMode.transportType == 'PubNub'){
          console.log(record)
    }else{
      console.log("No subscription")
  }catch(e) {
    console.log(e.message)
Dec 24, 2022 8:33 AM UTC
I just took it straight from the example here: https://developers.ringcentral.com/guide/notifications/push-notifications/quick-start which does have those lines in it.
Thanks for the readAllSubscriptions() function. That was telling me that I was missing the CallControl permission. Once I added that, it worked.
Merry Christmas Phong.
