Jan 10, 2017 7:33 PM UTC
WebHook not receiving calls
Hi All, I have successfully registered a WebHook for purpose of monitoring incoming calls. I am working against Sandbox environment. I am not receiving any calls on my WebHook.
I saw similar questions but they were resolved with no further explanation.
My webhook is a Java servlet, I utilized ngrok as advised. I am placing a call to sandbox phone number, then I am dialing extension 101, neither events send a call to my web hook. Here is how my subscription list look like:
{ "uri": "https://platform.devtest.ringcentral.com/restapi/v1.0/subscription";,
"records": [
"uri": "https://platform.devtest.ringcentral.com/restapi/v1.0/subscription/8418023a-3663-40c1-9a2b-f078d20b2...;,
"id": "8418023a-3663-40c1-9a2b-f078d20b2829",
"creationTime": "2017-01-10T18:42:50.856Z",
"status": "Active",
"eventFilters": [
"/restapi/v1.0/account/153525004/extension/153525004/presence?detailedTelephonyState=true&sipData=true",
"/restapi/v1.0/account/153525004/extension/153525004/message-store",
"/restapi/v1.0/account/153525004/extension/153525004/presence/line/presence",
"/restapi/v1.0/account/153525004/extension/153525004/presence/line/presence?detailedTelephonyState=true",
"/restapi/v1.0/account/153525004/extension/153525004/presence",
"/restapi/v1.0/account/153525004/extension/153525004/presence/line",
"/restapi/v1.0/account/153525004/extension"
"expirationTime": "2017-01-17T18:42:50.856Z",
"expiresIn": 601984,
"deliveryMode": {
"transportType": "WebHook",
"encryption": false,
"address": "https://33d7f758.ngrok.io/RingCentralTest/RcTest";
Jan 10, 2017 9:09 PM UTC
Check to see if you have enough calling credits. You are given 500 credits/month this is if you are not a paying customer in your sandbox account.
Jan 10, 2017 9:20 PM UTC
Kobie, thanks for reply. Where should I see my credits? I couldnt find any reference of 'Sandbox credit'. Also I dont think I have sone anything that could spend any kind of credit so far and I am not placing calls from API, I am trying to call my main companay number, expecting it will trigger a call to my subscribed WebHook
Jan 10, 2017 9:25 PM UTC
In your sandbox if you go into the call logs screen and on any row hover your mouse over the column called result a message bubble will appear letting you know if you have any or not. Also, if you call your company number with your mobile phone you should receive a message stating "Voice mail is full".
Jan 13, 2017 8:46 PM UTC
Problem solved. Extension must be in use(by a physical or softphone) otherwise webhook events are not sent.
Thank you all!
Found Your Voice
Jan 19, 2017 9:17 PM UTC
Thanks for the update and information, I totally forgot about that requirement. Appreciate you investing time and sharing the results.
Jun 2, 2017 12:42 AM UTC
I am facing same problem, I subscribed to webhook
Array ( [uri] => https://platform.ringcentral.com/restapi/v1.0/subscription/72905ffc-3bc4-4550-9e58-1b337b63cdc1 [id] => 72905ffc-3bc4-4550-9e58-1b337b63cdc1 [creationTime] => 2017-06-02T00:39:24.557Z [status] => Active [eventFilters] => Array ( [0] => /restapi/v1.0/account/466727023/extension/101/presence?detailedTelephonyState=true ) [expirationTime] => 2017-06-09T00:39:24.557Z [expiresIn] => 604799 [deliveryMode] => Array ( [transportType] => WebHook [encryption] => [address] => https://synpat.com/ringcentral.php ) )
When I cam calling, I dont get any notfication.
