May 16, 2025 4:32 PM UTC
What's the best approach to get notified when there's incoming call ?
Hi folks!
I’m using: https://github.com/ringcentral/ringcentral-softphone-ts
I think I can get notified through TLS connection but if I’ve like 10k users connected their ringcentral, will I have to got 10k TLS connection (each with their own SIP credentials) ?
Is there any better alternative option to this like receiving an API call to my webhook or something ?
Thanks in advance!
May 16, 2025 4:37 PM UTC
Yes you can via the telephony event notification. Please read this article to learn more.
May 16, 2025 4:44 PM UTC
You can get notifications like Phong Vu said. But in order to answer calls using the softphone SDK, you need to start a softphone SDK instance which will create a TLS connection.
NumeoThe First StepAuthor
May 16, 2025 5:54 PM UTC
Thank you for prompt reply!
another quick question: are there any limits for this telephony event notifications ?
May 16, 2025 9:00 PM UTC
