Feb 11, 2020 7:20 PM UTC
Why are there random delays with Webhook for active calls (/presence?detailedTelephonyState=true)?
We are noticing that some calls that come through are taking a long time to come through the webhook we have set up for an extension. I've tried to determine a particular pattern but it may be a 2-minute delay one time and a 15-minute delay the next time. Normally the calls come through in real-time.
Is there something in particular I could look at or a way to force the delay to be shorter?
Feb 13, 2020 12:56 AM UTC
How often do you get such a long delay? Can you log the notification which comes late and post them here so maybe we can run some checking. If this problem is consistent, please open a case by sending the question and some log on a support ticket for better support.
Feb 17, 2020 4:33 PM UTC
Thank you. I will put in a ticket. The delays range in time. Usually we see the notification in real time.
