Jun 3, 2017 11:51 AM UTC
Why can I not use password flow?
We are using RingCentral integration and we follow the password code flow. Now we are adding a webhook for instant notification. We are creating a new app, and we are a server/web platform with a public application. We are not able to use password flow. How do we add it? We need it to be done.
Jun 4, 2017 1:31 AM UTC
Password flow is not available for public apps for security reasons. You can change the app type to enable password flow.
Jun 24, 2019 4:15 PM UTC
Once an application is created in the dashboard, you cannot change the platform, permission, or even application type. You will need to create a new one from scratch.
You can submit a help support ticket to see if they can help.
