Nov 20, 2013 4:44 PM UTC
Incoming fax appears to be blocking subsequent calls from ringing through
It appears that incoming faxes that remain in progress for an extended amount of time are preventing incoming calls from ringing through. The incoming calls subsequent to the In Progress fax show as missed calls, but they never ring on our phones. Any idea what's going on here?
Dec 10, 2020 6:45 PM UTC
There can be different individual reason for different users. You can contact support here so that they can help you to investigate the issue and your config and will help to resolve.
