Aug 6, 2021 3:26 PM UTC
Activate lldp with polycom firmware 6.3.0.
It seems LLDP is always getting off even if its on. When I turn it off then on again, it starts LLDP again for a couple of minute, then goes down again. I'm trying to configure voice vlan with those VVX 450 and without LLDP, it is impossible.
Aug 6, 2021 4:07 PM UTC
You may have to factory reset the phone to disable LLDP and have the phone remember the setting configuration.
Aug 9, 2021 12:10 PM UTC
Do we know if Ringcentral will upgrade firmware someday?
