Feb 27, 2024 7:01 PM UTC
Add digits to end of an extension for paging system.
Hello! We are using an ATA setup as an extension to work with our paging system. Currently you need to dial the extension and when it is picked up you have to dial 00 for the zone. I am wondering if there is a way to include the 00 after dialing the extension so that users do not need to enter the 00.
Participating Frequently
Mar 1, 2024 2:00 PM UTC
maybe dial ext*00
Probably won't work, but don't see anyone else offering ideas.
