Sep 7, 2022 8:29 PM UTC
Analog phone on RingCentral using Polycom oBi302?
What is the best way to connect an analog phone through the RingCentral service using a Polycom oBi302?
tak-it1Answer
Found Your Voice
Sep 7, 2022 9:33 PM UTC
Not much to it, just register your OBi to RC and then plug your analog phone into Line 1 on the OBi.
tak-it1Found Your VoiceAnswer
Found Your Voice
pjfThe First StepAuthor
Sep 8, 2022 9:56 AM UTC
Thanks tak-it. Can you tell me where I can find information about registering the obi with RC?
