Jan 31, 2018 7:05 PM UTC
"Audio while connecting" and "hold music" volume adjustments will not save. It goes back to default LOUD volume.
Customers have complained about how loud the connecting and hold music is. There is a slider to adjust the volume, but it will not save. It goes back to the default, which is the full volume. This seems to be an oversight on the part of the programmers. Customers should not have to turn down their phones just for the hold music, then turn it back up to talk to someone. Hold music should be able to be set at a decent volume. Did you know that your hold music for Ring Central is extremely loud as well? I have to turn down my phone when I'm put on hold, then turn it back up when a customer support person gets back on the phone.
Dec 24, 2020 5:25 PM UTC
Jessica I have opened a ticket after receiving a similar complaint. I will update this thread when I get more answers.
Dec 24, 2020 5:50 PM UTC
Jessica this is what you can do (from RC Help-Edith)
You can convert the file with a lower volume by using a 3rd party site to convert the hold music to lower volume at https://www.onlineconverter.com/increase-mp3-volume
- Upload the audio file
- select decrease volume (%) - The higher the percentage, the lower the volume, try selecting decrease by DB if you like.
- Hit convert
- Click on Download now.
- Sometimes (with ads), hit the x button (top right corner) to start downloading the converted file.
- Create a template for your users with the newly converted hold music and apply it to them.
Apr 15, 2021 1:26 PM UTC
I am having the same issue, has this not been fixed yet?
I have the same issue, has this not been fixed yet?
