May 19, 2021 3:20 PM UTC
Call Handling Ring For settings
So this is odd. Why do the mobile and desktop apps ignore the Ring For setting when it's set for less than 3 rings? If I set it for 1/5 they still ring for 3/15. The Always ring 30 setting doesn't seem to make much difference here.
Worse, if the user has a physical phone then there's a 20-ish second delay in the physical phone ringing UNLESS I set the Desktop & Mobile to 0/0.
May 19, 2021 10:12 PM UTC
Hi John, this is currently a normal behavior with the call forwarding settings on the app. Fell free to add your suggestions or ideas in our
Ideas Portal at https://ideas.ringcentral.com/
