Jun 13, 2014 7:02 PM UTC
calls being sent to voicemail without 'do not disturb' being enabled
All of a sudden, incoming calls are going straight to voicemail without DND being enabled. The calls go to voicemail for a few seconds and then the line starts ringing even if the incoming call has hung up.... HELP! the boss is out of town.... lol
    Dec 21, 2020 10:50 AM UTC
    Facing almost the same issue. DND is not enabled still sometime call goes directly into voicemail
    Dec 21, 2020 12:12 PM UTC
    Check the User hours. If the user hour is custom and out of hours, this happens. Check the settings once
