Sep 23, 2023 9:45 PM UTC
Can i set up a call flow based on a dialing a code?
Sometimes the office is closed unexpectedly, I'd like for a way to have the receptionist just dial a keycode, or press a soft button that will just divert all calls to an out of office mailbox for our IVR. We used to be able to do this with our old system.
It's very frustrating that I have to log in and make the changes manually to our call flow.
Participating Frequently
Sep 24, 2023 6:29 PM UTC
Kind of difficult to suggest the best solution without knowing your setup.
Here are the KNOWNS
You have a receptionist (probably a Standard user)
You have an IVR menu
You want the receptionist to divert calls to a Message-Only-Ext. for out of hours.
Here are the UNKNOWNS
How does a caller reach the receptionist (Through an IVR menu? Through a Call queue without an IVR menu? directly? do they hear any greeting before connecting - if yes you probably don't want to play that greeting before diverting to out of hours)
Whatever the case, I'd expect you want your receptionist to either (1) use the "Forward all calls" or a "Custom Rule" to divert her calls...Or (2) give her Phone System admin access.
