May 11, 2023 1:27 PM UTC
Cannot make outgoing calls on LAN and WAN but can call using data
the dial button is gray and the error is- Sorry, something is wrong on our end, so calling is temporarily unavailable. Please try again later. been using wifi and lan connection but can't make outgoing calls. I can make calls using data connection on my mac and windows and can also make calls on mobile ios app using wifi. please help. Thanks!
    Jun 16, 2023 4:47 PM UTC
    I have an agent with the same problem. She was fine on an old laptop but they gave her a new laptop and it does not work. I deauthorized that old laptop but even when she signs in , still comes up with that error message. The IT in her building say that nothing is blocking the app.
    Nov 1, 2023 1:47 PM UTC
    Same issue - works outside of our network. In network, getting this error on RC app. Sorry something is wrong on our end, So calling is temporarily unavailable. Please try again later
    Jan 29, 2025 3:54 AM UTC
    Was this resolved? Having a similiar issue.
    Jan 29, 2025 6:53 PM UTC
    Hi ​@johnagarcia, if you're experiencing issues, I recommend submitting a ticket to our Tech Support team so they can take a closer look and assist you. You can do so here:
    🔗 Submit a Ticket
    Let me know if you need any help with the process!
