Oct 20, 2021 3:07 PM UTC
delay when clicking to place or answer a call
Hello. When I try to place a call, it takes 15-20 seconds for anything to happen. It's like it doesn't register any clicks. It doesn't matter if I try to place the call from call history or manually typing the number (typing is fine) and clicking the call button. When an inbound call comes, I click the icon to answer the call and it takes 15-20 seconds to register. The call almost always goes to voicemail because it takes so long.
I've tried uninstalling and re-installing the app several times and nothing seems to help. This is my first time using RingCentral. Not fun so far, please help :(
erikbrownAnswer
Feb 15, 2022 8:52 PM UTC
@Lisa Focaccia yes, I figured it out. It all came down to Jabra's software. Once I uninstalled it, stopped using their dongle and just connected my headset through the native Bluetooth connection on my laptop it worked fine. Hope this helps out!
Oct 20, 2021 3:12 PM UTC
Hi @Erik Brown Please submit a Tech Support Case so your app can be checked.
Feb 15, 2022 4:53 PM UTC
hello @Erik Brown, I am having the same issue. Did you ever get this resolved?
erikbrownThe First StepAuthorAnswer
Feb 16, 2022 10:50 AM UTC
thank you! it seems my IT department also found my issue. We updated my audio drivers and mine is working now as well.
Feb 16, 2022 3:30 PM UTC
@Erik Brown Thanks for sharing this!
