Found Your Voice
Oct 11, 2024 11:11 AM UTC
Difference between direct number v's softphone v's company number
Hi
Can you please explain the difference between direct number v’s softphone v’s company number?
Problem Solver
Participating Frequently
Oct 11, 2024 11:47 AM UTC
direct number - when called reaches a specific user extension. Each user gets 1 direct number which is tied to its license(this is called a DL- digital line). “Additional local numbers(ALNs)” can also be assigned to the user.
All ALNs are direct numbers.
Not all direct numbers are ALNs (for example DLs are not a ALNs, but they are still direct numbers)
One way to tell ALNs apart from DLs is that DLs have greyed out checkboxes - bulk actions are not allowed for them. In the attached pic 1 user extensions has 3 direct numbers. The greyed one is a DL the other ones are ALNs.
It’s possible to assign direct numbers(ALNs) to other extensions besides users.
company number - when called reaches the auto-receptionist for the site. From the auto-receptionist the company number might be routed to one of the following:
- a user extension (then it behaves the same as a direct number)
- a call queue
- other stuff
softphone - web app, mobile app, or desktop app. As opposed to a hardphone - which is a deskphone.
Found Your Voice
Oct 11, 2024 11:48 AM UTC
This is great and very helpful, thank you 😀
