Nov 3, 2026 10:10 AM UTC
Distinctive ring for calls coming from a queue on poly Edge 350
Need to be able to have a distinctive ring for calls coming from a queue (some users want to silence queue group calls BUT still be able to see it come in) … the pickup feature does not display the caller ID.  Have been trying to set this at the phone level, but need to have a number I can use to identify for the distinctive ring.  Ring Central seems to only transmit the outside caller’s number on the que.  I even tried to set up a different user to go through first to see if I could get a different caller ID number.
Yes, we can change the display to show the queue number, but that only changes the display, not the caller ID that is actually coming through on the calls.
*** Looking for any way I can either in the RC system, or at phone level … to create a distinctive ring (silent) for calls coming in through the queue.   I even played with adding an extra user and running calls through that prior to the queue … did not help.
Ring EX and Poly E350 phones
Crystal_
Crystal_Answer
Nov 12, 2026 4:05 PM UTC
Hi there! It sounds like you have already done some great troubleshooting on this.
The reason your phone-level distinctive ring isn't triggering is that RingCentral always passes the outside caller’s actual phone number through the queue so your team knows who is calling. Even when you change the queue display name or route the call through another user first, the underlying caller ID remains the external caller's number, which means your Poly E350 doesn't see a single "queue number" to match with a silent ringtone.
Since standard queue settings don't natively assign a silent ringtone on desk phones while keeping Caller ID visible, here are a few easy workarounds to consider:
1. Use the RingCentral Desktop App (HUD) for Visual Alerts (Best for Caller ID) If your users work at a computer alongside their desk phone, they can use the Heads-Up Display (HUD) inside the RingCentral desktop app:
  • Have those users monitor the call queue in the HUD rather than having the queue ring their physical Poly phone directly.
  • When a call enters the queue, a visual notification and the full Caller ID will pop up silently on their computer screen, allowing them to see who is calling and pick it up with a click—without their Poly E350 ringing out loud.
2. Set Up Presence Monitoring on the Poly E350 Instead of adding those users as ringing members of the queue, you can assign a Presence / Line Monitoring key for the queue on their Poly E350 (via Admin Portal > Users > Phone System > Phones & Devices > Presence):
  • When a call comes into the queue, the line key light on their Poly phone will flash silently to alert them visually, and they can press the button to answer. (Note: Similar to Call Pickup, this gives a visual alert rather than full Caller ID on the phone screen).
3. Submit a Support Ticket, we recommend submitting a support ticket through the RingCentral Support Portal (support.ringcentral.com) or your Admin Portal.
  • Let our Technical Support team know you are using RingEX with Poly Edge E350 phones and share what you have already tested. They can review your account setup and check if a custom device provisioning template or specialized call-routing workaround can be applied for your team.
Hopefully, one of these options gets your team closer to the quiet workflow they need!
Crystal_
Crystal_Answer
