May 12, 2023 4:13 PM UTC
Have a number that goes to Vmail will not ring
Have a number goes straight to VM. have turned off voice mail. We see the call as missed. Admin portal shows user as "offline" however user is logged in. calls appear on desktop app as missed. Test works , forwarding the number works. just wont ring desktop app. have checked all schedule and vm settings... Thank you
May 12, 2023 6:23 PM UTC
Hi John, we appreciate you for troubleshooting prior to reporting. Please submit a ticket with Tech Support to check other settings that may have caused the issue.
https://support.ringcentral.com/new-case.html
jjbakerThe First StepAuthor
May 12, 2023 6:30 PM UTC
Thank you. I resolved this by applying another "Template" to the user. That seemed to do the trick. Hope this helps anyone else with this issue. Regards John
May 12, 2023 6:34 PM UTC
Glad to know it's working now. Thanks for sharing the resolution, too!
