Nov 23, 2020 1:58 PM UTC
How do I forward my incoming faxes to someone else when I'm on vacation?
My direct phone number and direct fax number are the same. Is there a setting to make incoming faxes go to someone else when I'm on vacation?
    Nov 23, 2020 5:40 PM UTC
    See the below reference:
    https://support.ringcentral.com/article/9787.html
    This article provides instructions for Administrators on how to configure the Message Recipient feature of other Users to allow other Extensions to receive their respective voicemail and fax messages.
    Nov 23, 2020 5:47 PM UTC
    Thank you!
    Feb 9, 2026 2:45 PM UTC
    That support link no longer directs to anything. What is the resolution for this?
    We’re having the same issue.
    Feb 9, 2026 5:43 PM UTC
    Good catch, thanks for flagging this! Here’s the updated KB Support link you can check out: https://support.ringcentral.com/article-v2/How-to-create-and-assign-a-Fax-Only-Extension.html?brand=RC_US&product=RingEX&language=en_US
