Jul 18, 2018 6:14 PM UTC
How to turn off Ring Out and Turn on Direct
I am in outgoing calls on my computer app. Recently the app switched on the RingOut feature auto magically. I go in to the setting to direct dial and that feature is no longer there. How can I get it back?
l.olsonThe First StepAuthor
Jul 18, 2018 7:39 PM UTC
I am on 10.1.2  I log in using my email which is linked to my direct number.
Jul 18, 2018 8:33 PM UTC
Hmm....what happens when you log in with your direct number?
Jul 18, 2018 9:24 PM UTC
From the admin screen I had to deactivate the account and reactivate the account. Now it works!
Jul 18, 2018 9:30 PM UTC
Weird! It must have gotten stuck on the back end or something. Glad it's working now!
Aug 14, 2018 10:45 PM UTC
this has happened to 3 different users for us. Might be worth looking into as we haven't found a resolution yet.
May 4, 2020 4:16 PM UTC
Any update on this? The same issue
May 5, 2020 7:09 PM UTC
Also having same issue, some devices using the same line can switch, others cannot
Jul 30, 2020 3:45 AM UTC
Hey l.olson,
What version of the softphone are you on? How do you log into your extension? With a direct number or the main company number + your extension?
Dec 12, 2024 3:07 PM UTC
Can confirm that disabling the account for a moment resolved this issue today on version 24.3.0.47527
