Mar 14, 2022 10:53 PM UTC
Is it possible to customize the incoming call pop dialog?
We have RingCentral integrated with Zoho CRM and when phone calls come in, the RingCentral extension displays an incoming call pop window. In the window is information about the caller (if it matches a record in the CRM database) and offers options for typing in notes into a 'description' text field.
My question is: could another function be added to this dialog window? Say, an attach file function?
Thanks in advance for any help.
Answer
Mar 15, 2022 4:37 PM UTC
Hi @Tom Knowles
I am assuming that you are using the RingCentral integration for Zoho which can be found here
https://help.zoho.com/portal/en/kb/crm/extensions/telephony/articles/ringcentral-integrate#Making_calls_through_RingoutIf
If my understanding is correct, this integration is developed and managed by the Zoho team and you might have to check with the Zoho developers/community to get better help on this.
Hope this is helpful!
Thanks!
Answer
Hi @Tom Knowles
Thanks!
tom-5The First StepAuthor
Mar 15, 2022 6:54 PM UTC
Yatin,
Thank you for responding in an intelligent and polite manner.
Determining which group would be able to handle this IS an important first step and I wasn't sure if this was a RC thing or ZOHO thing.
I'll pursue it with ZOHO and see what it goes....
Thanks!!
