Mar 1, 2024 8:05 PM UTC
Is there any way an incoming called can leave a voicemail directly, without waiting for the call to ring?
When someone from outside our organization calls in, is there a way for the caller to send their own call straight to voicemail? We have an answering service that helps us answer calls and we want them to try to transfer calls to us when possible, but there are times when it would be better for them to just send the call straight to our voicemail.
Mar 1, 2024 11:13 PM UTC
This feature is currently unavailable, @Roth. You can submit a request for it in our Ideas Portal at https://ideas.ringcentral.com/.
Participating Frequently
Mar 1, 2024 11:39 PM UTC
while ringing press # to go straight to voicemail.
