Aug 25, 2021 11:08 AM UTC
Microphone Settings Not Being Retained
We've been having an issue with Max users that keep having an issue with their internal microphone picking up the background noise. We restart the client etc and the only way to allow them to not pick up background noise is to disable the Microphone. However this isnt really a solution.
What is odd is that people will be fine and then it occurs.
Aug 25, 2021 5:52 PM UTC
Hi @John King, please clarify the issue. Are you getting this trouble in the RingCentral app?
