Apr 28, 2025 5:05 PM UTC
No Audio in Headset when I enable headset control buttons
So, I have a really strange issue.  I’m using the RC desktop app with a Jabra Evolve2 55 headset.  Works great, EXCEPT if I enable headset control buttons:
The moment I activate this feature, I can no longer use the headset for outgoing calls.  I can answer incoming calls just fine (even using the call answer button on the headset), but for all outgoing calls, it’s as if the headset loses pairing.  No audio or microphone.  As soon as I toggle the control option off, the headset works normally again.
Anyone run into this before?
