Mar 10, 2021 9:59 PM UTC
Polycom vvx350 my phone rings when speed dial contact is called.
I have a user that has a few speed dials setup on his phone. However, for one of his contacts, if that contact receives a call, his phone will ring too. I've looked everywhere for a setting but can't find how to turn that off. What is the secret? Thanks.
Mar 10, 2021 10:12 PM UTC
Hi @Robert Wingerter, is this contact one of the account users?
Mar 10, 2021 10:17 PM UTC
Please check on the KB article below and follow instructions until No. 12. You need to disable "Enable me to pick up a monitored line on hold".
https://support.ringcentral.com/article/How-to-set-up-Presence-permissions-for-your-own-line.html
Mar 10, 2021 10:29 PM UTC
"Ring my phone" was not selected. I enabled, saved, disabled, saved. System never asked me to reboot phone, but I unplugged the phone (network and power), waited 30 seconds, plugged it back in and same result.
Mar 10, 2021 10:37 PM UTC
sitting at user's desk and does not matter what the setting is in "presence" -- checked or unchecked for "Ring my phone when any user I am monitoring rings " . phone does reboot and restart when changing settings.
Mar 10, 2021 10:51 PM UTC
that was the first thing checked on both user phones. Neither have forwarding.
Mar 10, 2021 11:03 PM UTC
Thank you for trying! I thought I was missing something.
Found Your Voice
Mar 31, 2021 3:39 PM UTC
Your user has likely set a ring tone under Settings -> Basic -> Ring Type -> Attendant Calls. If there's anything other than "silent ring" set for Attendant Calls, any presence line will ring with that tone.
Mar 31, 2021 6:02 PM UTC
It was a system bug - and fixed in the last Polycom Update.
Mar 31, 2021 6:10 PM UTC
Great to hear, @Robert Wingerter!
