Aug 14, 2024 2:26 PM UTC
red light won't stop flashing - polycom VVX 410
We have a seasoned employee that has been using ring central desktop app for a long time.  Her Polycom vvx 410 phones red light stays on even after she has deleted all the messages, faxes, and etc .  We tried a couple of things like restarting the phone.  This will work until someone calls, then it stays on until we reboot the phone.   We also did a update that was inside the app but that didn’t fix the issue.  Please help.
Aug 16, 2024 3:24 PM UTC
Hello! This issue could be related to a network. I recommend reviewing our network recommendations for desk phones, which can be found at:
https://support.ringcentral.com/article-v2/Network-requirements.html?brand=RingCentral&product=RingEX&language=en_US
This resource will provide you with valuable information to help troubleshoot and optimize your desk phone's network connectivity.
If you need help, please submit a ticket at https://support.ringcentral.com/new-case.html.
Problem Solver
Participating Frequently
Aug 17, 2024 12:21 AM UTC
sounds like she has unread voicemail messages.
You said you deleted all the voicemail messages.
Have you double checked the Admin portal > Users. There is a Msg. column that indicates how many voicemails a given extension has. What do you see in the Msg. column for her extension?
You can ask RC to disable the WMI (Waiting Message indicator - also known as MWI), so that the light stops flashing even if you do get a voicemail.
And if all else fails, there isn’t anything that a bit of duct tape can’t fix. Make sure it’s black electrical tape in this case.
Aug 21, 2024 4:59 PM UTC
Follow the instructions below, it may seem like a lot, but it only takes a few seconds and will resolve the issue.
In the admin portal select the user>notifications>Messaging Notifications>change the pull down from “Basic Settings” >Advanced Settings>select Customize Notifications for voice mail>check the box for Mark message as read once emailed>done>saved.
Aug 22, 2024 5:34 PM UTC
I had the same issue and I called RC.  They had to do a factory reset on my Yealink phone.  It took some time but got it resolved in one call.
