Oct 23, 2026 3:06 PM UTC
Ring after completed call
Every time I complete a call (or anyone does) the desktop phone makes a small ring sound.  How can I stop that?  It does it no matter if I hit end call or place the receiver down.   We have Poly Edge350 phones if that matters.
    Nov 11, 2026 6:58 PM UTC
    That little post-call chirp is super common, and the easiest fix is usually turning off the Call Disconnect Tone right in your RingCentral settings. RingCentral has a built-in chime that plays the moment a call ends, which often sounds like a mini-ring.
    Here is how to turn it off:
    1. Open your RingCentral app (desktop or mobile).
    2. Click your profile picture/initials in the top corner and open Settings.
    3. Head over to the Phone section.
    4. Scroll down to General and look for Call disconnect tone.
    5. Switch that toggle to Off.
    Place a quick test call to see if your phone hangs up quietly now!
    (If it still chirps after that, it is likely the Poly phone's own "Attendant Ring" reacting to monitored lines. You can silence that directly on the phone by pressing the Home button > Settings > Basic > Ring Type > Attendant Calls, and setting it to Silent Ring.)
