Mar 3, 2021 7:05 PM UTC
System wide speed dial
Is there a concept of a "system wide speed dial" - I.e numbers we can program in that can be speed dialed from either a soft button on each phone, or dialing a special code (I.e. dialing "*1" from any phone on the platform would call a number we have defined in the system?)
    Mar 3, 2021 8:36 PM UTC
    Hello @Don Zelenak, for feature requests, please submit it in our Ideas Portal here.
    Found Your Voice
    Apr 1, 2021 9:14 PM UTC
    You can create a queue, close it for all hours save for 15 minutes on a day you won't need the speed dial (say, Sunday from 2am - 2:15am) -> Call Handling and Forwarding -> After Hours -> Forward to external number -> enter the number.
    There is a limit of 100 call queues per account, so this may not work if you have multiple in use queues and/or over 100 #s you need as speed dials.
    Apr 1, 2021 9:42 PM UTC
    This is actually a brilliant idea (Speed dial with a defined number) . This will actually save time in calling most frequent or emergency numbers. But as per I am concern its still not there in the system. If you can create this as an idea on idea portal, I think RC team can look into this as a future implementation.
