Apr 13, 2022 7:02 AM UTC
Yealink T46G registration problem
I'm trying to set the Yealink T46G phone to RC, we enter all the data manually, but it won't pass the registration. Does anyone know what the problem is?
Apr 13, 2022 4:01 PM UTC
@Strong Purple Please check the correct process of manually provisioning your Yealink phone from the KB article. If it doesn't help, you may contact our Tech Support or submit a ticket at https://support.ringcentral.com/new-case.html
Apr 13, 2022 8:18 AM UTC
Hi @Strong Purple
I am moving this question to the customer space because I think you will get a better response there
