Sep 30, 2022 2:30 PM UTC
How do you lock rinerg volume on a Yealink T57U phone.
How do you lock rinerg volume on a Yealink T57U phone. The operators turn down the volume and dont answer the calls or pages.
Sep 30, 2022 5:51 PM UTC
Hi Joseph, do you mean ringer?
Brett1685885021
Oct 13, 2022 12:17 PM UTC
Joseph,
Our organization needed the same thing accomplished. We were able to utilize a custom config file.
This will likely require a custom configuration file for your environment's provisioning server. You can discuss with your account rep to explore options.
Oct 13, 2022 2:43 PM UTC
Thanks for helping, @Brett McVay!
@Joseph Varona, if you need help reaching out to your account rep, let me know.
