Aug 5, 2026 3:23 PM UTC
Incoming Call Report with Detail
I am looking for a report that shows the number of calls that are inbound to our main number and what option they selected from the phone tree over a specified period of time. For example, I want to know for July 8th how many calls we received during a specified time that went to option 1, option 2, etc.
Aug 14, 2026 5:49 PM UTC
Hi ​@GEitel,
Here is how you can pull that report:
How to Run the IVR Option Breakdown Report
To see how many calls came into your main line and which options callers selected (Option 1, Option 2, etc.) for a specific date like July 8th, you will want to use the IVR Analytics feature in Performance Reports.
  1. Log into the RingCentral Admin Portal.
  2. Go to Analytics > Performance Reports.
  3. Set your Date Range to July 8th (and adjust the time filters if you need a specific hour window).
  4. Switch the report view/tab to IVR Menus.
  5. Select your main Auto-Receptionist / IVR Menu.
  6. Review the Menu Selections / Key Actions table—this will display the exact volume and percentage of calls that selected Option 1, Option 2, and so on.
