Feb 3, 2020 6:41 PM UTC
2 channel audio and bitrate for recordings
Can Ring Central recordings be enabled for 2 channel audio (where the 2 sides of a call are on isolated channels L/R or otherwise?)
Also, can the sampling rate be improved to a higher rate than 8000hz?
We are trying to determine if we can support a solution that currently uses 2 channel recordings @22,050hz from Twilio with a RingCentral recording or if the solution will have to stay on Twilio.
    Feb 3, 2020 8:12 PM UTC
    Hi Dan,
    2-channel audio recording is still as a plan and upcoming (I have no due date though). For the sampling rate, I believe that right now, it is automatically set to either 8kHz or 48kHz when handshaking based on the connection bandwidth.
    Jun 3, 2025 4:17 PM UTC
    Is 2 channel audio recording supported now ?
    Jun 10, 2025 4:55 PM UTC
    Unfortunately, due to the low demand on this feature, it’s still not supported.
    Nov 22, 2026 10:03 PM UTC
    Low demand or a lack of desire to actually give your customers what they want?
