Apr 14, 2026 2:27 PM UTC
TAS-106 on /telephony/sessions/{conferenceId}/parties/bring-in during merge; conference create works
Hi everyone,
I’m implementing merge in a Laravel app and need confirmation on expected behavior.
Stack
  • PHP SDK: ringcentral/ringcentral-php 3.0.4
  • WebPhone SDK (ringcentral-web-phone-2)
  • Using call-control + telephony conference APIs
Flow
  1. Create conference
    POST /restapi/v1.0/account/~/telephony/conference → 200
  2. Bring in active calls into conference
    POST /restapi/v1.0/account/~/telephony/sessions/{conferenceSessionId}/parties/bring-in → 403 TAS-106
Observed app result
  • /api/r/call-control/merge returns 409 Conflict
  • Message: Bring-in was rejected (TAS-106). Automatic transfer fallback to conference target is disabled.
Sample payload that still fails (even with -1 parties)
  • primary_party_id: ...-1
  • secondary_party_id: ...-1
  • Still gets TAS-106: Operation is not allowed
Scopes
CallControl, ReadPresence, VoipCalling, and other standard scopes are present.
Has anyone seen TAS-106 for bring-in/merge while conference creation works?
Is this usually account/role/call-leg restriction, and what exact setting/feature enables this?
Apr 14, 2026 2:54 PM UTC
I tried this a long time ago so I don’t really remember the exact steps to setup a conference call.
I am not sure where you got the /call-control/merge endpoint that you said it returns 409 conflict.
You can read and follow the instructions from this dev guide and try it again.
Apr 25, 2026 2:26 PM UTC
Thanks for the pointer. We reviewed the official conference guide and our flow is aligned with it:
Clarification: /api/r/call-control/merge is our internal backend wrapper route. Inside it we call official RingCentral APIs:
  1. POST /restapi/v1.0/account/~/telephony/conference (works, 200)
  2. POST /restapi/v1.0/account/~/telephony/sessions/{conferenceSessionId}/parties/bring-in (fails with 403 TAS-106)
We also establish the SIP host leg before bring-in. Conference creation + host join works, but bring-in is rejected (TAS-106 Operation is not allowed) for both -1 and -2 party IDs.
Can you confirm whether this indicates account/role/call-leg restrictions for bring-in/merge on these sessions?
Apr 27, 2026 7:45 PM UTC
Can you simply test your account/extension with this webphone demo app to see if conference call works with the user you want to start the conference.
https://ringcentral.github.io/web-phone-demo/
Apr 28, 2026 12:57 PM UTC
Thanks for the guidance. I want to clearly separate what we tested in WebPhone Demo vs our Laravel integration.
What we tested in WebPhone Demo
- We tested with the same account/extension.
- Conference creation works.
- “Invite to conference” (Bring-in flow) also works in that demo scenario.
- The demo is useful to validate conference + bring-in behavior, but it is not our full app merge wrapper flow.
What we implemented in our Laravel app
- We use official RingCentral APIs (no unofficial endpoint):
  1) POST /restapi/v1.0/account/~/telephony/conference
  2) POST /restapi/v1.0/account/~/telephony/sessions/{conferenceSessionId}/parties/bring-in
- Our `/api/r/call-control/merge` endpoint is only an internal wrapper that orchestrates these official API calls for two active calls.
- So “merge” in our app = create conference + bring-in call A + bring-in call B.
Important technical note
- Conference API itself is working in our app.
- Bring-in also works in some conference scenarios.
- The blocking issue is specific merge scenarios where bring-in for certain live call legs returns TAS-106 (Operation is not allowed), even after trying party-id variants (-1 and -2).
Request for confirmation
Can you confirm whether there is any issue in this approach, or if TAS-106 here indicates account/extension/call-leg restrictions for these specific calls?
If restricted, please share the exact required role/feature/call conditions to allow this merge path.
Apr 28, 2026 2:41 PM UTC
The issue appears to be somewhere in your code. I recommend submitting a developer support ticket and providing the code where you handle conference calls. Specifically where you start a conference, create a new call, and call the bring-in endpoint. Without reviewing the code directly, it's difficult to pinpoint the exact cause.
