Jun 16, 2019 1:48 AM UTC
call dies when using RingCentral app and switching between wifi and cellular and vice versa - please fix
when on a call using RC app (I use iPhone xs max) and phones switches between wifi and cellular (both ways) the call terminates and tries to recover but never successful.
Jun 17, 2019 5:34 AM UTC
Hi Nailian, thank you for the feedback and sorry for the inconvenience.
To help us figure out the root cause, could you pls send us the feedback when you meet this issue next time?
Here is how to send the feedback:
  1.  Reproduce this issue
  2.  Go to "Help" >> "Report Issue"
  3.  Enter the issue description and the time when the issue happens.
  4. Tap "Send"
Once receiving the feedback, our dev will look into it.
Best Regards!
Jun 17, 2019 8:22 AM UTC
Hi Nailian,
I test RingCentral app on the same device iPhone xs max(OS12.2), but fail to reproduce it
1. Call in progress in WiFi
2. Walk to somewhere the wifi is lost, but 4G still on
3. Walk back to the place where the wifi is back
Actul result:
Step2: call is reconnected, call parties can hear each other
Step3: call is reconnected, call parties can hear each other
is this the same scenario you ran into? could you tell which carrier you are using? Looking forward to your response
Best regards
Nina
nailianThe First StepAuthor
Jun 18, 2019 7:53 PM UTC
Yes this is the exact scenario.
I have AT&T.
