Apr 22, 2025 12:57 PM UTC
Help needed setting up Cisco ATA 192 to fax
Hello,
I have an ATA 192 w recieved with our Spectrum\Ring central service. The company has never set it up to use with our fax (which is on a standard fax line atm). I would like to get it setup to fax using the ata 192 but have no clue where to start….
Pete
Moore Industries
    Problem Solver
    Participating Frequently
    Apr 22, 2025 11:03 PM UTC
    start by reading this article:
    https://support.ringcentral.com/article-v2/Fax-Set-Up-Analog-Telephone-Adapter-ATA.html?brand=RC_US&product=RingEX&language=en_US
    Follow steps 2-5 in that link. If you get stuck at some point ask here again.
    btw… step 3 is telling you to toggle off “Play music while connecting” - previously the proper way of doing it was to set it to “Ring tones”. Maybe both configurations are fine, just don’t leave it as Music.
