Oct 28, 2026 4:00 PM UTC
how to listen to audio recordings of phone calls?
So we have automatic call recording on. It has the message when we answer calls, we get the transcripts, but can’t find the actual audio recordings when customers call in. Where can we find these? Thanks
    Brett1685885021
    Oct 29, 2026 7:34 PM UTC
    If you got to RingEX Admin > Analytics and logs > Call Log > Filter > Types of calls > Recorded calls only: Do you have any recorded calls? If not, there is likely a recording config issue in your environment somewhere.
    Brett1685885021
    Amplifying the VIBE
    Oct 31, 2026 4:07 PM UTC
    Also make sure to click on the Customize Columns and check the box by Recording so you can see teh Recording column.
    Nov 2, 2026 5:32 PM UTC
    ​@darcBDC, don’t forget to mark one of the replies as the Best Answer if it helped resolve your concern! 🙂
